 HK450 By Phoenix
MensagemAssunto: HK450 By Phoenix   1st Fevereiro 2012, 19:14
aleluia este ano sai meu heli!!!!!!!!!!!!
mandei vir da hk um hk450 ccpm assim que chegar vou postar as fotos de montagens, espero que os amigos do foro que voa heli me ajudem heheheheheh
componentes escolhidos (wish list minha na hk aushuashuh):
heli escolhido HK-450GT CCPM 3D Full Alloy Helicopter Kit (Align T-Rex Compat.)
Hobby King 401B AVCS Digital Head Lock Gyro
Turnigy 2200mAh 3S 20C Lipo Pack
Peel-n-stick foam tape. 10x5inch 4mm thick
Curved ball link pliers 5mm
Nylon XT60 Connectors Male/Female (5 pairs) GENUINE
4mm Gold Connectors 10 pairs (20pc)
ciclo 3x Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec
cauda 1x D922MG Digital Metal Gear Servo 1.8kg/ 12g/ 0.07sec
TURNIGY 3A UBEC w/ Noise Reduction
TowerPro H40A Brushless Speed Controller
Turnigy 450/500 H2223 Brushless outrunner 3500KV
ohh to sumido não em hehehe
demorei mais ta ai foto do heli
segue pequena lista que mandei vir pra complet
ar o heli
Turnigy 2836 Brushless 450-Size Heli Motor 3 1 Reserved
TURNIGY 3A UBEC w/ Noise Reduction 1 Reserved
TURNIGY TRUST 45A SBEC Brushless Speed Contr 1 Reserved
Hobby King 401B AVCS Digital Head Lock Gyro 1 Reserved
Corona Digital Servo 2.2kg / 12.5g / .11sec 3 Reserved
Turnigy 2200mAh 3S 25C Lipo Pack 1 Reserved
R/C Helicopter Pitch Gauge 1 Reserved
4mm Gold Connectors 10 pairs (20pc) 1 Reserved
Nylon XT60 Connectors Male/Female (5 pairs) 1 Reserved
Curved ball link pliers 5mm 1 Reserved
Peel-n-stick foam tape. 10x5inch 4mm thick 1 Reserved
HK450V2 Main Gear Set 1 Reserved
Turnigy Heat Shrink Tube 30mm Black (1mtr) 1 Reserved
Turnigy 4mm Heat Shrink Tube - RED (1 1 Reserved
Turnigy 5mm Heat Shrink Tube - BLACK (1mtr) 1 Reserved
Turnigy 4mm Heat Shrink Tube Yellow (1mtr) 1 Reserved
Turnigy 6mm Heat Shrink Tube Blue (1mtr) 1 Reserved
Turnigy Heat Shrink Tube 50mm RED (1mtr) 1 Reserved
4 Min Clear Epoxy 1 Reserved
Polyester Velcro Peel-n-stick adhesive side 2 Reserved
TL-680 Thread Locker & Sealant Ultra High St 1 Reserved
Scorpion Lipoly Lock Strap 230mm (Medium) x 1 Reserved
T-Neckstrap TURNIGY Transmitter Strap 1 Reserved
Turnigy 9X 2.4GHz 8Ch Receiver (V2) 1 Reserved
Turnigy 9X LCD Backlight Kit - Green (DIY) 1 Reserved //vo acender a tela do meu radio hehehe
Última edição por phoenix em 1st Outubro 2012, 09:06, editado 1 vez(es)
MensagemAssunto: Re: HK450 By Phoenix   1st Fevereiro 2012, 20:14
Legal. Eu to loko pra compra um Smile
MensagemAssunto: Re: HK450 By Phoenix   1st Fevereiro 2012, 21:52
Tudo é baum demais, só que vais ter q treinar muiiiiiiiiiiiiiiiiiiito pra poder voa-lo com segurança.
Um dia compropum tambem.............
MensagemAssunto: Re: HK450 By Phoenix   3rd Fevereiro 2012, 23:16
logico ne ^^ pretendo mais montalo pra voar no campo perto de casa durante a manha bem cedinho heheheheh
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 00:19
as pecas estão boas, quando tiver duvidas grita ai no que puder ajudo.
não se esqueça simulador desde já.
no começo não tente sair voando e sim só mantém-lo parado na sua frente o tal do hovering. no mínimo dez horas dele.
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 08:27
Comprei esse vamos ver se da pra brincar, acho pra voar de boa sem manobra vai.
http://leaderhobby.com/product.asp?ID=9394001223866
Quando chegar pego carona no tópico do amigo e posto fotos.
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 08:36
esse da para voar de boa até vôo invertido faz, ja é um de passo coletivo ou seja 6 canais.
talvez tenha que trocar o gyro apenas para fazer 3D.
outra dica embora tu ja tenha comprado acha peças de reposição fácil para ele? pois heli no começo se quebra muito.
digamos tem até um kit crash ou seja toda queda é certeza que quebra.
segue a listinha.
cano da cauda
eixo principal
eixo das pás
pás principais
eixo do rotor de cauda
coroa dentada ou main gear
isso que quedas leves.
precisando estamos ai.
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 09:18
K XIIIIIIIIIQUE....!!!!!!!!!!!!!!
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 09:46
segue a listinha.
cano da cauda
eixo principal
eixo das pás
pás principais
Lá na leaderhobby.com tem peças e tem uns up's de aluminio até que com um preço bom, vamos ver se a minha experiencia com o micro HK 190 http://www.hobbyking.com/hobbyking/store/__18746__HobbyKing_HK_190_2_4ghz_4Ch_Fixed_Pitch_Helicopter_RTF_Mode_2_.html me ajuda, pelo menos acho que da uma noção
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 09:54
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 10:22
se acha peças tranqüilo só alegria, quanto aos upgrades fique com as plásticas mesmo até ficar bom. pois as plásticas são mais resistentes, as de alumínio ou quebram ou entortam. se bem que a de alumínio são mais bonitas.
quanto ao micro HK 190 te digo ajuda e muito a ter uma noção de vôo e hover. ajuda nos reflexos. muito bom.
eu mesmo antes de voar meu passo coletivo voei muito tempo com um 4 canais também só que coaxial.
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 11:20
Tendo alguma dúvida vou te encher a paciência um pouco rsrsrsrsrs
Vou seguir sua dica e colocar aluminio só quando estiver bom de dedo, valeu Mori!!!
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 12:53
mori vou fazer so hover sim heheheheh pelo menos até me acostumar a estabilizar o heli um hover a 1,5m de altura ja nao tem o efeito solo né ?
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 12:59
sim já acima de um metro já diminui bastante. mas no começo para se economizar umas pás principais não se esqueça do X trainner.
MensagemAssunto: Re: HK450 By Phoenix   4th Fevereiro 2012, 13:00
enche nada, no que eu souber estamos ai.
MensagemAssunto: Re: HK450 By Phoenix   22nd Fevereiro 2012, 21:21
chegou o danado hehehe e ja montei o bichin pra por na estante até chegar a eletronica hehehhe,
alguns pontos:
maingear empenada (acho q fui sortudo pois nao fui taxado .-.)
e heli apenas montado por cima pra ver o stilo do "novo brinquedao"
MensagemAssunto: Re: HK450 By Phoenix   22nd Fevereiro 2012, 23:37
fótos do bixinhu..................
MensagemAssunto: Re: HK450 By Phoenix   23rd Fevereiro 2012, 08:34
caracas pensei que já estava fazendo 3D ahsuahsuahsuas
MensagemAssunto: Re: HK450 By Phoenix   24th Fevereiro 2012, 19:42
O meu clone chegou hoje, e o melhor não fui taxado!!!
Com frete ele saiu por 150 doletas com controle e lipo 3s 2.200mha.
[img] [/img]
[img] [/img]
MensagemAssunto: Re: HK450 By Phoenix   25th Fevereiro 2012, 07:39
eita agora vamo bora avua rapaz
MensagemAssunto: Re: HK450 By Phoenix   25th Fevereiro 2012, 08:21
Pior que cheguei ancioso ontem a tarde em casa, mas além de estar ventando muito estava garoando Crying or Very sad
Só testei o bichinho e guardei, tomara que hoje quando chegar esteja um tempo melho.
MensagemAssunto: Re: HK450 By Phoenix   25th Fevereiro 2012, 08:26
não esqueça do X treino, vai te poupar umas pás principais.
MensagemAssunto: Re: HK450 By Phoenix   25th Fevereiro 2012, 08:42
Isso não posso esquecer mesmo rsrsrsrsrs
Valeu!!!
MensagemAssunto: Re: HK450 By Phoenix   26th Fevereiro 2012, 09:19
e ai rapaz como foi a estréia?
MensagemAssunto: Re: HK450 By Phoenix   26th Fevereiro 2012, 10:56
Mori o tempo ta feio aqui, vento forte e esta ameaçando vir aquela chuva e eu não tenho um local fechado para estrear o bichinho Sad
HK450 By Phoenix
 :: INTEGRAÇÃO :: HELICOPTEROS, VOO LIVRE-
